where is the video effects folder I don't have one only a effects folder help!! I know this a stupid question but I am new and hungry for this program
geposted Fri 27 May 05 @ 10:16 am
create VideoEffects folder inside C:\Program Files\VirtualDJ\
but i think you should have it there. if still using version 3.01 (without logo in the video window)
geposted Fri 27 May 05 @ 10:52 am
I dont have it there let me get this straight. I just got the program yesterday. I do th esetup then I make a folder called C:\Program Files\VirtualDJ\ I add the spv files into the folder and the visuals should work? They don't work for me. I also checked the box in config that says show video plugin but the section is blank
geposted Fri 27 May 05 @ 3:32 pm
The exact directory is VirtualDJ(backslash)Videoeffects. (The 'backslash' charactercouldn't be displayed here.
If your VirtualDJ root is C:(backslash)Program Files(backslash)VirtualDJ then the video effects directory is C:(backslash)Program Files(backslash)VirtualDJ(backslash)Videoeffects
Just move your video plugins there.
geposted Sat 28 May 05 @ 10:22 am
C:\\Program Files\\vdj2\\VideoEffects
is my folder
just testing, you have to write \\\\ in order to write \\ :-)
is my folder
geposted Mon 30 May 05 @ 1:10 am
