Forum: Old versions
Topic: BCD 3000 and VDJ5
Just got this. Im a newbie at dj controllers. I have VDJ5 and i am wondering how to get the music to play out of my computer speakers(computer has a cheap on-board sound card Realtek HD audio) and cue a song in my headphones with the bcd3000. Right now all I get is sound out of my headphones. I have gone to config, but I must be missing a step in VDJ5. Can someone please help. Thank you in advance!
PS: Do I also need an USB sound card?
geposted Mon 10 May 10 @ 6:40 pm
Give us your pc specs, so we can help your further
Your controller has an audio interface already.
This is the one you need, if you don't already.
This is Midi|audio Drivers : http://www.behringerdownload.de/B-Control_download/BCD3000-Vista-XP-1.2.0.0.zip
This is asio4all : http://tippach.business.t-online.de/asio4all/downloads_1/ASIO4ALL_2_10_beta1_English.exe
Asio4all, if you use this, you cannot hear pfl (cued song).
It is another audio driver.
If you run Windows 7
-Always run as administrator (VDJ.exe Right Click & Choose)
-Config, Audio Setup
-Inputs - None (Only if your have timecode)
-Outputs - Headphone (Headphone + Speakers)
-Master Chan 1|2 - Headphone Chan 3|4
-Sound Card - BCD3000 (Behringer)
-Uncheck Apply Eq to external inputs
Try this, then if your hear popping, grumbling, weird noise through speakers.
You'll need to modify Performance tabs as you need.
Behind your BCD3000
-RCA Master outputs (L&R)
You'll need a RCA male to 1|8'' female 3.5mm, to your pc sound system.
Thanks for your help in my previous post Everyone! Greatly appreciated.
New Problem. The jog wheels in my bcd3000 aren't working correctly now, when i try to slow or speed up the song by touching the jog wheels it actually stops the song. I have shut off the scratch button but it still does it. At first , in scratch mode, it would let me stop the song to beat match but if I was holding the jog wheel the song would re-start from the point i stopped it at after about 5 seconds with me still holding the jog wheel. Also, I always have to press a button twice to activate/deactivate something. Someone has told me this is a mapping issue. Can some one PLEASE instruct me which mapping file to download and HOW to get it to work in VDJ5.
Many thanks.
PS: Running Windows XP Home, P4 2.4GHZ Intel with 1GB RAM(Performance is fine) 250 GB HDD.
Please use the latest v6.1 trial https://virtualdj.com/download/trial.html and it should work a lot better. In the latest version, you can also toggle scratch on/off by going to CONFIG -> Options.
The jogwheels on the BCD2000 are not touch-sensitive, so they will only pause the song and scratch while the jogwheel is moving. If you stop and hold the jogwheel, then song will start playing again after a short period of time (Once it has determined that you have stopped moving the jogwheel.)
If you are serious about scratching and need to be able to hold the music as you can with vinyl, then you will need to upgrade to a controller that has touch-sensitive jogwheels, such as Vestax VCI-100, Pioneer CDJ-400, etc.
