Fellow turntablists, yesterday i made a cd and recorded it thru my creative labs recorder... Unfortunately the recording level a bit low. Following the recording, I went to edit the tracks through CD creator Version 6-- i opened up the file and inserted tracks... When I went to hear the CD is when I noticed that the CD recording level was low. Is there any way that I can go in and modify the volume through a program (maybe even CD creator has that option), in other words increase the volume of the file/recording--that way I can burn the CD again but with better volume.
any input would be helpful.
dj Kiteman
dj Kiteman
geposted Fri 27 May 05 @ 6:20 pm
dj kiteman - check out this thread. It might give you some answers:
https://virtualdj.com/forum/display.html?topic=12712
geposted Fri 27 May 05 @ 6:48 pm
just took a look... like all things this is chinese to me right now.. but im sure after reading up w/ time I'll be able to fix my problem.. The gain b/w songs is fine.. its just that i lowered the volume for recording bc i would blow my neighbors ears off
geposted Fri 27 May 05 @ 7:06 pm
