I just got the program yesterday. do I do the setup then I make a folder called C:Program FilesVirtualDJ I add the spv files into the folder and the visuals should work? They don't work for me. I also checked the box in config that says show video plugin but the section is blank I have no video effect folder when I start
geposted Fri 27 May 05 @ 7:46 pm
the visuals should be in the folder called "visual effects", a subfolder to your Virtual dj folder
geposted Fri 27 May 05 @ 8:11 pm
I dont have it should I reinstall?
geposted Fri 27 May 05 @ 8:42 pm
strange
would try a reinstall, yes :)
geposted Fri 27 May 05 @ 8:54 pm
ok maybe its the way I am installing it because now I dont see a folder in my programs just a icon on the start button
geposted Fri 27 May 05 @ 9:09 pm
ok dj-in-norway everything is good now thanks for your help
geposted Fri 27 May 05 @ 9:43 pm
good ;)
geposted Sat 28 May 05 @ 2:41 pm
