Hey Virtual dj world, I have been using the multi instance skin on my pc side of my mac book pro for a while now and the memory space is getting cramped and unorganized, it would love to just do my mixing on my mac side but the multi instance skin does not come in a mac download. Is there a way to take the multi instance skin here, link to skin https://virtualdj.com/addons/967/Multi-Instance_Skin_variations.html, from my pc side and take it to my mac side and use it there? Let me know because this would save me some stress.
Thanks you DJs
Josh=?
Thanks you DJs
Josh=?
geposted Fri 14 May 10 @ 3:16 pm
All you need to do is run the .exe in Windows which will create the .zip in Documents > VirtualDJ > Skins. You then need to copy the .zip file to your Mac drive Documents > VirtualDJ > Skins (same as windows)
The mac version will then pick it up just like the windows one.
Only problem may be if any of the fonts aren't in Mac but you will see that straight away. You can either add the font to the Mac side or edit the XML.
Keith
Keith
geposted Fri 14 May 10 @ 3:22 pm
O soo close, i did every thing you said and it opened the skin fine but only one instance opens, only one window of virtual dj opens. Its weird too because i downloaded a different multi instance skin earlier today,
link here https://virtualdj.com/addons/8672/Hercules_Steel_(multi_instance).html
and it too only opens one instance. Any suggestions?
Thanks for you help
Josh=?
Thanks for you help
Josh=?
geposted Fri 14 May 10 @ 4:32 pm
Not sure how multi instance works, sorry .....
Hopefully someone will come along soon who knows about this!
Keith
Keith
geposted Fri 14 May 10 @ 5:05 pm
Thanks Keith for your help, Is there some one out there that can help me? Please...
geposted Tue 18 May 10 @ 1:28 pm
