Hi all.
I'm working on an advanced mapping for my Hercules RMX.
Almost every single button has multiple functions and the whole console is having 4 different operating modes.
With all these modifications my RMX is starting to be an awesome tool for great DJing.
As soon as I finish and debugging and modeling this script I will post it here with some instructions on how to use it.
But now I need some help.
I'm stuck with something ridiculous, but just can't get through it.
I need to know the name of a command I bet it exists, but don't know which is.
What I need:
As simple as scrolling up and down the GREEN bar of the effect selector.
To move the same bar in the browser I use browser_scroll +1/-1
But nothing in the effects page seems to do the same
I tried ffects_scroll, effect select, effect slider but nothing seems to work.
Please VDJscript experts, can you help me?
What I need:
geposted Fri 14 May 10 @ 3:52 pm
Simply use effect select +1 and effect select -1 if assigning to buttons.
A full list of VDJscript verbs can be found on the following page: http://www.virtualdj.com/wiki/VDJscript_verbs.html
Also, see http://www.virtualdj.com/wiki/VDJscript.html
Once finished, you can upload your custom mapping to http://www.virtualdj.com/addons/upload.html
geposted Sat 15 May 10 @ 1:09 pm
