how it works ??
somebody knows ??
somebody knows ??
geposted Sat 28 May 05 @ 7:20 am
I use it all the time, set shortcuts to the favorite folders by changing the value,
i think valie=0 is for playlists (the first favorite folder)
We asked for this. The difference is that instead of go directly to the favorite folders,
sometimes (when you have subfolders open) it goes to a subfolder instead of the favorite.
I' m not sure if i like that, i prefer to go and EXPAND the "favorite" folder only.
Try it and let me know, if we have to suggest some corrections on this.
But in general this command has speed up my navigation to my music folders.
geposted Sat 28 May 05 @ 4:04 pm
If you use the search-option and you like to know where the file you found is located use the (go to folder) option and you there!!!!!
geposted Sun 29 May 05 @ 8:03 pm
