Hey guys i did start a form on the PC side about how to turn the multi instance skin that i have here,
https://virtualdj.com/addons/967/Multi-Instance_Skin_variations.html
and turn it in to a mac skin which i did fallowing the instructions of copying the multi instance skin zip file in the skin folder of virtual dj on my pc and copying it over to the skin folder of virtual dj on my mac. It worked almost flawlessly. It opens fine and all but it only opens one instance, as you may figured out I want it to open multiple instances, like it does on the pc side.
for people who don't know what the multi instance skin does, it allows you to basically have more then one window of virtual dj open at a time which allows you to to have more then two decks, its wonderful.
Another thing to add is I did download a different multi instance skin yesterday and it too only opens one instance. So I am starting this forum because it seems to be a mac problem now. How do I get this multi instance skin to work?
Thanks every body for your help
Josh=?
Josh=?
geposted Sat 15 May 10 @ 11:33 am
come on peps where is the love?
geposted Sun 16 May 10 @ 4:34 pm
Im starting to lose hope here =(
geposted Tue 01 Jun 10 @ 4:34 pm
I would also be interested in this issue (if it's right - can anybody confirm this?), so why aren't multi instances working on mac?
I'm planing to use multi instance on my mac in the near future (not doing it yet), that's why I'm asking...
geposted Wed 02 Jun 10 @ 4:40 pm
Yea! what that guy said..
Here is the link to the other multi instance skin i down loaded, that too doesn't work
https://virtualdj.com/addons/8664/Hercules_Steel_(multi_instance).html
oooo Hercules Steel!!!!!
but the description is in spanish tho and I was thinking of getting in contact with this deedstacktyk but i don't speak spanish homies, nor do i really know how to get in touch with him.
Any way if any knows what could be the problem any help would be appreciated. Thanks
Josh=?
Josh=?
geposted Thu 03 Jun 10 @ 2:38 am
LOL is not spanish, is french !!
geposted Thu 03 Jun 10 @ 4:55 pm
HAHAHAhahaa!! thanks for the correction, yea its french!
but seriously I need some help guys and not just with foreign languages.
Any help would mean so much to me thanks.
Josh=?
Josh=?
geposted Thu 03 Jun 10 @ 6:32 pm
Multi-instance is not supported on mac, its not the skin, the Mac version of VD6 simply unable to do multi-instance - thats what VD6 tech-team told me, you have to use Pc version with Bootcamp
geposted Sat 05 Jun 10 @ 11:04 am
poop, that sucks
wish the VDJ team would have told me sooner
well thanks any way
Josh =(
well thanks any way
Josh =(
geposted Sat 05 Jun 10 @ 11:39 am
