I've just uploaded two new video transitions.
They are simple 'blind' effects - H-Blind has horizontal blinds that move vertically, V-Blind has vertical blinds that move horizontally.
You can configure the direction of movement (up/down, left/right depending on transition) and you can configure the number of blinds from 1 to 100.
Once approved by Atomix they should be available in the plugins download section.
Please note that these are PC only at present as I no longer have access to a Mac for compilation and testing I'm afraid.
geposted Mon 17 May 10 @ 7:02 pm
Magic Scott, thanks very much, can't wait to use them.
geposted Tue 18 May 10 @ 2:21 am
These transitions are now available for download.
http://www.virtualdj.com/addons/effects.html?category=trans&order=default&platform=all&search=
geposted Tue 18 May 10 @ 8:05 am
Nice one, cheers!
geposted Tue 18 May 10 @ 12:32 pm
Thanks Scott GREAT as usual!!!
geposted Thu 20 May 10 @ 5:22 am
Thanks Scott...
Joey....
Joey....
geposted Thu 20 May 10 @ 4:45 pm
Nice transitions Scott, but there is a small bug that also appears in some other transitions:
the right deck's aspect ratio isn't kept when crossfading the videos.
geposted Thu 20 May 10 @ 6:01 pm
Thanks for pointing that out - which other transitions have the same problem? Just mine?
geposted Thu 20 May 10 @ 7:11 pm
I will test them all this weekend.
I don't remember which ones have the problem.
geposted Fri 21 May 10 @ 10:26 am
nice work!
geposted Sun 23 May 10 @ 10:56 am
Thank you you're the best. You really need to be given credit because you're one of the only ones I see actually creating plugins for vdj.
geposted Mon 24 May 10 @ 5:58 pm
great job as allways. Thank you Mr SBDJ !!!
geposted Mon 31 May 10 @ 2:52 pm
