I need some help connecting everything.
ok first off i have a numark m3 mixer
next i have numark tt 1625s with traktor timecoded records.
oh and i have behringer ufo202's
basically how do i connect all this together to VDJ?
geposted Thu 20 May 10 @ 3:40 pm
Theres a pic on behringers site that shows how to set everything up with that soundcard.
http://www.behringer.com/EN/Products/UFO202.aspx
geposted Sat 22 May 10 @ 11:01 pm
i looked at it but where do connect my mixer to?
ive never connected my decks or mixer to vdj or a laptop so im new to this
geposted Sun 23 May 10 @ 5:36 pm
First of all, you will need a 4-in/4-out ASIO sound card to be able to do timecode. The Behringer does not have enough inputs and outputs (Unless you are only using one deck.) You will ideally need a card such as Hercules DJ Trim, Native Instruments Audio 4 DJ or ESI Maya44 USB.
See page 9 of the quick start guide for setup information https://virtualdj.com/images/pdf/VirtualDJ6-SetupQuickGuide.pdf
And https://virtualdj.com/wiki/TimeCode%20Config.html
geposted Mon 24 May 10 @ 7:50 am
thanks for the links oh and i have 2 of the behringer 202's so i can run 2 decks
geposted Wed 26 May 10 @ 12:59 pm
