Hi there,
I'm not sure if this is possible but if not t would be good, I have tried mapping this using my DJM800.
Bascially It would be good if there was a way to map a dial on the mixer to choose a video transisition rthaer than using the mouse everytime. Basically to scroll through transitions.....
geposted Fri 21 May 10 @ 6:21 am
This is already possible.
geposted Fri 21 May 10 @ 8:09 am
The action you need to map is video_transition_select - See https://virtualdj.com/wiki/VDJscript_verbs.html
geposted Fri 21 May 10 @ 9:07 am
Yeah I tried that but it wouldn't work. I'll try again using a different dial!
geposted Fri 21 May 10 @ 9:34 am
You'll either want a button (or two) or an endless encoder sending relative position data really.
geposted Fri 21 May 10 @ 10:42 am
