Hi guys
I have a few issues regs video djing
A. Why does audio load really slow while using visuals rather than a video
B. When projecting the secondary screen to venue tvs, the monitor screen sits behind virtual dj software. Should this happen/is it correct procedure?/Am I doing something wrong?
geposted Fri 21 May 10 @ 8:43 am
B. select dual display on your lappy and in VDJ go to config > video > select your video card and not window > activate.
geposted Fri 21 May 10 @ 9:28 am
A. By default VDJ limits the speed files (using the internal decoders) load at when the video engine is active in order to prevent dropped frames. Visuals usually use more CPU than video playback (especially on lower specced systems) so the effect would be more pronounced.
You can disable this bby using the Registry Tool to enable the SpeedLoad option.
geposted Sun 23 May 10 @ 12:08 pm
"You can disable this bby using the Registry Tool to enable the SpeedLoad option."
Where is this on virtual dj? or do you mean "use hardware acceleration" Or am I just getting confused"
I have tried using proggrammes like speed up my pc Is there any other software that anyone would recommend?
geposted Wed 09 Jun 10 @ 4:19 am
Download the Registry Tool from the VirtualDJ Download Plugin Page. Then enable SpeedLoad option.
geposted Fri 11 Jun 10 @ 10:48 am
Your current licenses do not allow you to download Tools
geposted Mon 14 Jun 10 @ 4:36 am
The registry tool is for Professional Edition, not Home/Console/Limited Editions I'm afraid.
geposted Mon 14 Jun 10 @ 11:16 am
shocking behaviour this. Even though ive bought pieces of hardware related to virtual dj. There is still restrictions!
geposted Tue 15 Jun 10 @ 4:23 am
No;
You bought a piece of hardware from Numark that came bundled with a free limited version of Numark Cue known as Numark Cue LE. This free version has various restrictions I'm afraid; one of which is a limitation on what content you are able to download from this site.
A lot of content is reserved for users who have purchased the full Professional Edition - which incidentally you can upgrade to for a significant discount.
I'm sorry that you feel this is shocking behaviour but it is no secret that the limited edition has, well, limitations.
geposted Wed 16 Jun 10 @ 6:32 pm
Yeah your right
geposted Fri 18 Jun 10 @ 9:03 am
