Forum: Music discussion
Topic: Twitter Problem
I'm not sure who is in charge of it, but I thought that I'd mention an issue on the Twitter page.
Your API tweets are posting the link as www.virtualdjradio.com instead of http://radio.virtualdj.com, so your Twitter followers are going to get errors if they follow the incorrect link. I came across the issue while I was poking around on Twitter and sent a tweet to the page from doctordjct with the correct link.
I hope you get it worked out.
DJ Doc
geposted Fri 21 May 10 @ 3:53 pm
Also it only list CH1.
geposted Fri 21 May 10 @ 11:08 pm
geposted Mon 24 May 10 @ 7:32 pm
dj-in-norway wrote :
try the link http://www.virtualdjradio.com ;)
EDIT: ah.. thanks for spotting the hijack.. fixed now
I think the link you posted is some kind of spyware or something, it flashed my screen sayin I was infected!! Yup it just shut down my other comp something aint right here!!
geposted Mon 24 May 10 @ 7:47 pm
yes, the http://www.virtualdjradio.com was hijacked..
Now its fixed.. was a tiny bug left, that i missed first try fixing it .. works all fine now :)
geposted Mon 24 May 10 @ 8:02 pm
I'm glad to hear it's sorted, Norway ;)
I just tried the link, and all is OK!
geposted Sun 30 May 10 @ 8:46 pm
