On my gigbox I use the RME HDSP RPM (or digiface, bith do the same). NO matter whether I use ASIo or WDM drivers I get a very weird 'choppy' soudn when pulling back on Timecode or on the disc in the skin, not the normale reverse I get when using other audio IO options.
I am only experienceing this problem with VirtualDJ, the regular DJ software I use is fine..
Needles to say I cannot take VDJ out to field test it unless this gets reolved.. I am pretty sure it is not a problem with either the interface or teh PC as it only happens with VDJ..
geposted Sun 29 May 05 @ 8:27 pm
I did a complete re-install on my gig machine an both ethe reverse play and video issues are still there (reverse play sound like a buch of bleeps and blobs instead of reverse playback, video gets out of sync quickly and is far from smooth)
The weird thing is these problems do not come up on my other two systems but outside VirtualDJ anything else works perfectly fine on the same system..
geposted Tue 31 May 05 @ 12:47 pm
