hi there,
is there a reason why i can`t listen to the tune i want to bring in on headphones.
e.g.
one song playing to a crowd, another ready to come in, but i can`t hear it through my headphones.
Is this because its only the trial version, or do i need an adaptor for my pc ?
If i want to listen to audio on headphones, i have to unplug my speakers.
thanking you in advance
J
e.g.
J
geposted Mon 30 May 05 @ 12:58 am
it´s coz u got the trial version,
Buy the full ver and u could listen through your headphones.
it´s worth it i promise:)
geposted Mon 30 May 05 @ 1:09 am
not the compete truth
anyway if you have soundcard capable of connecting more that 2 speakers
all is fine you can play one song for the crowd in the speakers and the other only in the headphones
it you can only connect 2 speakers you can use cheap Y splitter and
in the left channel of the pc output you will have music for the crowd (that wil play mono in both speakers for the people) and in the right channel you will have mono signal for your headphones which with correct Y splitter will play in both headphone sides the same)
anyway you can mix with your pc, without buying any new hardware :-)
just few bucks for the full version
geposted Mon 30 May 05 @ 1:44 am
Separate outputs is disabled in demo version.
geposted Mon 30 May 05 @ 8:42 am
Cheers for that,
just as i thought, hmmm now to ponder on will or won`t..... ?
thanks for your help
James
James
geposted Mon 30 May 05 @ 12:25 pm
2 stereo outputs are possible in vdj, just not with the demo.
geposted Mon 30 May 05 @ 12:45 pm
With full version you can use all outputs you want, several soundcards if you want (Windows can't use many soundcards).
For example I use two different outputs for Deck A & B, and another soundcard for samples.
geposted Mon 30 May 05 @ 8:35 pm
