I'm just in the prosess of starting a turntable timecode setup (by the way im a new to this) is it possible to hook turntables up to the laptop via a BEHRINGER BCD 2000 as a sound card or would i still need something like a maya44 to hook them up?
like i say im no expert or pro dj so would be greatfull of the help
would be thankfull for any advice
thanks
Matt
thanks
Matt
geposted Fri 28 May 10 @ 1:10 pm
also where can i find the time code vinyl?? cant find them anywhere can find the rane ones just no virtual dj ones
geposted Fri 28 May 10 @ 2:04 pm
also is it the pro version of the software i will need?
geposted Fri 28 May 10 @ 3:32 pm
VirtualDJ timecode records are no-longer currently available.
Serato CV02 vinyls can be used, or you might be able to find Numark VirtualVinyl records still for sale.
geposted Fri 28 May 10 @ 3:36 pm
thanks for the info
you got any idea about the other question?
geposted Fri 28 May 10 @ 3:54 pm
30+ veiws and no replys i presume nobody knows haha :P
geposted Sat 29 May 10 @ 6:40 am
Perhaps the users who have viewed so far do not use timecode and/or do not know anything about it?
To use timecode, you will need a 4-in/4-out ASIO sound card such as Hercules DJ Trim, Native Instruments Audio 4 DJ, ESI Maya44 USB, etc.
The sound card in the BCD2000 is best avoided because due to poor design it causes nothing but problems for most users.
Setup instructions and a diagram can be found on page 9 of the quick start guide: https://virtualdj.com/images/pdf/VirtualDJ6-SetupQuickGuide.pdf
For detailed configuration instructions, please see https://virtualdj.com/wiki/TimeCode%20Config.html
geposted Sun 30 May 10 @ 2:10 pm
