Hello,
I did buy Maya44 and now I've connected my CDJ100 to the soundcard and i've downloaded the Timecode file from this website.
I think something is wrong with the settings:
1. The cue button in my CDJ100 isnt really "cueing", its just "pausing"
Where may I find the best settings for Timecoes on VirtualDJ with CDJ100?
geposted Mon 31 May 10 @ 3:15 pm
geposted Mon 31 May 10 @ 3:21 pm
I read this...
Just tell me, Virtual Dj 6.0.5 + CDJ100 + Maya44 + Timecodes(downloaded from this website) may work PERFECTLY?
geposted Mon 31 May 10 @ 3:28 pm
I look at the wiki page here: https://virtualdj.com/wiki/TimeCode%20Config.html
I look at the picture of the "noisemap", this is the picture in the wikipage: https://virtualdj.com/image/10864/22773/noisemap.png
and THIS IS MY noisemap: http://img535.imageshack.us/img535/3486/88617278.jpg
why?
The song is just playing, but i dont see any noisemap...why is that?
why?
geposted Mon 31 May 10 @ 3:50 pm
For the timecodes downloaded from this site, you have to use the second part (VDJ timecodes). :)
Also: first thing you should do is lower your "gain", it seems like it's wayyyy to high.
geposted Wed 02 Jun 10 @ 9:03 am
Ok, i fixed the signal, but i dont see any green cicle in the noisemap window..
Plus, my cue isnt totally working...I mean, if i try to cue in 00:00:50, i hit cue, and it will actually cue 00:00:52..why?
geposted Wed 02 Jun 10 @ 7:45 pm
Your second problem is probably due to the lead time. In your timecode settings you can indicate how much time you leave between the start of the record and vdj's start. It's mostly useful for vinyl.
Can you give me another screenshot of what's wrong with the signal? :)
geposted Thu 03 Jun 10 @ 3:31 am
Alright, there is some news:
I tried the Serato Timecode CD today, and there's a signal (green circle),
but still, if click cue on a beat (00:00:01) it will still cue 00:00:03...WHY ?!
geposted Thu 03 Jun 10 @ 8:41 am
I told you: that's the lead time. By the way: what difference does it make it it's 2 hundreds of a second off? Without lead time it's probably fixed.
geposted Thu 03 Jun 10 @ 12:13 pm
It makes a difference because I set cue point straight when the beat stars, and then I hit the cue button and it misses the beat.
The following picture shows the problem:
http://img295.imageshack.us/img295/3300/85385101.jpg
BTW, lead time is already set to 300ms
geposted Fri 04 Jun 10 @ 12:57 am
Which mode are you in? Rel, Smart or Abs?
geposted Fri 04 Jun 10 @ 6:12 am
Smart
geposted Fri 04 Jun 10 @ 5:45 pm
Can you check if it also happens in Absolute mode? I know Smart mode had some cueing problems on my vinyl.
geposted Sat 05 Jun 10 @ 4:33 am
it doesnt change anything
geposted Sat 05 Jun 10 @ 8:23 pm
Hmmmm... Havent seen this one before. Can you give me another screenshot of your timecode signal in action? Maybe it needs a little more tweaking?
geposted Sun 06 Jun 10 @ 4:33 am
sorry for the late answer..look at this picture:
http://img138.imageshack.us/img138/2842/timecode.jpg
geposted Tue 08 Jun 10 @ 12:54 pm
Okay you can turn the gain or the sound card's input up quite a bit, untill the circle touches the box :)
I would say: put the sound card input at about 50% volume. :)
geposted Tue 08 Jun 10 @ 3:35 pm
ok, then what?:)
geposted Wed 09 Jun 10 @ 2:09 pm
Which settings do you have in the debug window?
geposted Thu 10 Jun 10 @ 3:08 am
When I set input to 50% volume, the circle got squared.
I leave the input like it was in the picture, but ive turned the gain on. (the circle touches the box now)
he is the debug settings:
http://img815.imageshack.us/img815/8014/blablah.png
geposted Thu 10 Jun 10 @ 7:34 pm
