Hi guys, just wanted some confirmations on a few things.
Im doing my first gig at a club next week and wanted to know exactly what i'll have to do to configure my virtual dj 5 pro.
The venue has cdj 1000 mk3s i believe. What will i need to be able to connect my pc to them. I normally connect up to cdj 400s but they're obviously easily configures to vdj. How does the setup differ?
Cheers
Cheers
geposted Tue 01 Jun 10 @ 1:46 am
just take your 400's and use them.
geposted Tue 01 Jun 10 @ 6:08 am
Unfortunately they're not mine to take. I use them on my radio show so they're owned by the station. Using a laptop would just make it a lot easier for transfering my music and give me a bit more confidence with it really
geposted Tue 01 Jun 10 @ 11:43 am
Unlike the CDJ-400, CDJ 1000's are not MIDI controllers and can only be used via timecode CD.
You will need a suitable ASIO sound card with 4 inputs and 4 outputs such as Hercules DJ Trim, Native Instruments Audio 4 DJ or ESI Maya44 USB.
Timecode CD's can be created yourself using the file downloadable from https://virtualdj.com/products/timecode/cd.html - Simply use your CD writing software to burn a couple of audio CD's using this file.
Setup instructions and a diagram can be found on page 9 of the quick start guide: https://virtualdj.com/images/pdf/VirtualDJ6-SetupQuickGuide.pdf
NOTE: These are for the latest v6 version - Please register https://virtualdj.com/users/edit.html and upgrade to the latest version https://virtualdj.com/download/updates.html or use the latest v6.1 trial https://virtualdj.com/download/trial.html
geposted Tue 01 Jun 10 @ 12:14 pm
so how would you dj anywhere else but the station without you own gear? maybe your not ready to play in a club?
geposted Wed 02 Jun 10 @ 8:49 am
