Hi just lately i have noticed when playing a track about a minute in i get a 1 beat stutter, i use the RMX, i get this only once per track i have played the tracks normally through my media player and they are fine do i have a setting wrong?
geposted Fri 04 Jun 10 @ 7:09 am
Here's some things to check:
Are you pressing play before the track has fully loaded?
Have you checked your perfermabce settings? If you have the slider set fully to the left (fastest) try coming back a notch (towards better quality) and see if that helps. If not try another notch. And leave all the VDJ settings underneath as they are.
If you continue to get issues, come back and we'll try and narrow it down. We'll also need more details on system specs etc. The more info the better.
Cheers,
Roy
Cheers,
Roy
geposted Fri 04 Jun 10 @ 11:35 am
If the audio cuts out or 'glitches', then this may be due to a performance problem with your computer.
Please see the following for tips on how to resolve common performance problems:
https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
geposted Fri 04 Jun 10 @ 12:57 pm
Hi my system is:
AMD Athlon Dual core 5200+ 2.61 ghz
4 gb Ram
GeForce 8800gts x2 Graphics Cards running in SLI mode
32 bit Operating System
Windows 7 Home premium
Audigy 2 Platinium zs sound system
Hercules RMX.
I have tried the fixes given but i still get this 1 beat stutter like it has missed the beat the track stays in sync it just annoying.
Sorry for taking so long to get back have been away for the weekend ;-0
geposted Sun 06 Jun 10 @ 1:12 pm
