ok so i just bought the american audio versaport... and im trying to use it for timecoded cds but it doesn't work. I can control the music and everything but there is no output audio what so ever... but if i change the inpute to a regular.. (no timecode) i get audio output... im not sure if this is a vdj problem... or hardware problem. i have the driver for the soundcard installed on a vista computer... and downloaded the 64x driver that i needed.. but it doesnnt seem to work... any help please?
geposted Fri 04 Jun 10 @ 11:44 pm
Hello I have the same sound card and it works very well for the time code but do not forget to press the Phono, since there are 4 inputs 4 outputs
She has a great sound, I do but is also ripped vinyl
geposted Sat 05 Jun 10 @ 3:03 am
can you please write like a lil step by step on how you setup everything up.... and how you have the settings on virtual dj please?
geposted Sat 05 Jun 10 @ 9:07 am
This will get you going:
https://virtualdj.com/wiki/TimeCode%20Config.html
geposted Sat 05 Jun 10 @ 10:51 am
i understand that i have to configure the timecodes... but im noting getting any audio out of the soundcard when i have the timecodes on.. when i take it off in options then i have music coming out of the soundcard and into my mixer... i need to figure that out so then i can configure the timecodes
geposted Sat 05 Jun 10 @ 2:32 pm
