Can somebody tell me where the preseted maps in vdj 6.08 is located in windows?
It would help a lot.
thanks
thanks
geposted Sat 05 Jun 10 @ 11:06 pm
They are built into the program.
If you modify a mapping, then it will be saved in My Documents\VirtualDJ\Mappers
NOTE: You should download the latest v6.1 trial https://virtualdj.com/download/trial.html
geposted Sun 06 Jun 10 @ 5:57 pm
