Hi all,
I'm proud to introduce... MultiFunctions 6.0 ! => http://www.virtualdj.com/addons/11588/Multi_Functions_6.html
Base resolution is 1440x900. More (resized) resolutions will be submited tonight. Follow this post to stay up to date (and on tweeter to be even more up to date !: @SQuatsoft).
Resolutions list:
-1440x900 (base)
-1024x768
-1280x800
-1366x768
-1680x1050
-1680x1080
-1920x1080
An user manual is available at: http://files.squatsoft.com/MultiFunctions%206.pdf
Please read this manual before asking any question ;)
Waiting for your feedback,
SQ;p
Resolutions list:
-1440x900 (base)
-1024x768
-1280x800
-1366x768
-1680x1050
-1680x1080
-1920x1080
SQ;p
geposted Fri 11 Jun 10 @ 8:49 am
Resolutions list:
-1440x900 (base)
-1024x768 cool!!
-1280x800
-1366x768
-1680x1050
-1680x1080
-1920x1080
i am fan of your multifunctions 3 is very simple to use!!!
thank you squatman!!!
regards
DJ POTTER PRODUCTIONS
-1440x900 (base)
-1024x768 cool!!
-1280x800
-1366x768
-1680x1050
-1680x1080
-1920x1080
regards
geposted Fri 11 Jun 10 @ 9:06 am
(Please note that 1440x900 is the base resolution. Other resolutions are auto resized with JeremK Skin Resizer tool.)
geposted Fri 11 Jun 10 @ 9:15 am
Thanks a lot, I'll give your skin a try.
Many thanks for harmonic mixing issue, that's a nice idea!
Greets and keep spinning ;-)
geposted Sat 12 Jun 10 @ 3:25 am
Can you add 1900 x 1200 screen resolution the list for us macbook users :-)
geposted Sat 12 Jun 10 @ 5:16 pm
Love it Love it Love it superb skin, loved 5 now 6 what's next :-)
geposted Mon 14 Jun 10 @ 4:08 pm
I'm really looking forward to the skin in 1280x800 resolution. Once it comes out I think it will be the only skin I use.
geposted Mon 14 Jun 10 @ 6:12 pm
7 I think... not sure... then 8 if I'm right :)
Thanks for your comments, resizes will be posted soon (as soon as I've finished a little bug shooting ;) ) with MF6.0.1
SQ;p
PS: They will be only resize (with Jeremk's skin resizer tool), not full re-work for each size, did you get that? (I don't want you to be disapointed) ;)
geposted Mon 14 Jun 10 @ 11:11 pm
This is without a doubt an amazing piece of skinning! I am very impressed. :)
geposted Tue 15 Jun 10 @ 3:13 am
Thanks a lot ;)
geposted Tue 15 Jun 10 @ 1:52 pm
can give link download ???
geposted Fri 15 Apr 16 @ 12:49 pm
geposted Fri 15 Apr 16 @ 1:08 pm
