I'm a VJ in Detroit using Virtual DJ. I ended up using the skin "Video VDJ:1024x768" to use features that I like.
Is/are there keyboard mapping commands for this skin?
The crossfade lever is tricky to "mouse" in the club.
Can I map the arrow keys to do this?
Anyone know?
Thanks,
Doug
Anyone know?
Thanks,
Doug
geposted Sun 13 Jun 10 @ 11:20 am
You can pretty much map any command you want to the keyboard I believe. Here is the list of verbs, http://www.virtualdj.com/wiki/VDJscript_verbs.html.
Hope this helps
Huey
Hope this helps
Huey
geposted Sun 13 Jun 10 @ 11:55 am
Thanks Huey, but the link didn't bring anything up.
Has it been renamed or something?
Thanks,
Doug
Thanks,
Doug
geposted Sun 13 Jun 10 @ 2:39 pm
Hmmm, thats weird. Well go up top on "Community" then click on "Wiki & Manuals" then under "Manuals & Guides" click on "VDJscript" then scroll down to where it says "List of the Verbs" and click on that then the list should appear.
Hope that helps
Huey
Hope that helps
Huey
geposted Sun 13 Jun 10 @ 2:48 pm
Found it.... thanks!
geposted Tue 15 Jun 10 @ 11:22 am
