When I am loading the next song while the other song is playing I get a stutter sound on the song that is playing. Also Whenever I am searching for music The song playing will cut out for a split second. I noticed that if I am doing pretty much any activity while a song is playing my CPU usage gauge is all the way up. These cut outs and stutters are very noticeable during my gigs. I my Processor to slow to handle this program? I am using a AMD Athlon Processor TF-20 1.60 GHz.
geposted Sun 13 Jun 10 @ 1:09 pm
This is most likely due to performance issues with your computer. 1.6Ghz is slow, but should be OK for basic audio mixing (Not timecode.)
For tips on how to solve common performance problems, please see https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
geposted Sun 13 Jun 10 @ 8:54 pm
What would be optimum for the program?
geposted Mon 14 Jun 10 @ 10:12 am
Please see https://virtualdj.com/products/virtualdj/
Your computer should meet and ideally exceed the recommended specifications listed at on this page.
geposted Tue 15 Jun 10 @ 6:37 pm
I have a 1.6 Ghz processor as well. I have minor issues with that, but they are not very noticeable. You can probably tweak your settings and be able to effectively mask the issue. Been doing it for a year now.
geposted Wed 16 Jun 10 @ 6:52 am
