Forum: Old versions
Topic: need quick tutorial on different controllers
I want to know the difference between MIDI controllers and other controllers.
Like is there a distinct difference?
Is there a sound difference?
Which ones are better?
Or is it based on the environment you're using it in?
geposted Sun 13 Jun 10 @ 4:54 pm
GOOGLE.COM
There are two different stands - MIDI and USB HID (Human Interface Device.) The later is superior - Please see https://virtualdj.com/wiki/HIDvsMIDI.html for an explanation.
There is no sound difference - The sound card (If the controller has one) is completely separate to the controller aspect. Sound cards typically use either USB or Firewire and the more expensive, generally the better the quality.
