Hello,
My son recently changed jobs and his new club uses Virtual DJ 5. At his previous club, songs were played for a maximum of 5 minutes and then another song was started for 5 minutes. He would also like to be able to do this in his new club. Is there a way to fade in, automatically, from say Deck 1 to Deck 2. He would then watch the time display to time out at 5 minutes to do this changeover operation.
Thanks, Lloyd
Thanks, Lloyd
geposted Sun 13 Jun 10 @ 5:47 pm
If you are playing songs in automix, then you can simply double-click on the next song in the playlist at the appropriate time to fade into it.
If you are mixing manually, then the action mix_now will allow you to do this. You will need to assign this to an appropriate key on your keyboard (Or a MIDI controller if you have one) by going to CONFIG -> Mappers (See below.)
The default skin in VirtualDJ v6 shows both elapsed and remaining time, so you can easily see when the correct time is to do this.
To map/change mappings:
For further information, please see:
https://virtualdj.com/wiki/VDJScript%20Examples.html
https://virtualdj.com/wiki/VDJscript.html
https://virtualdj.com/wiki/VDJscript_verbs.html
- Go to CONFIG -> Mappers
- Choose the appropriate device from the drop-down list, e.g: Keyboard, Hercules DJ Console, etc. or Simple MIDI Wrapper for a MIDI capable controller that does not have built-in (Native) support.
- Click the + (Add) button, then press the key/button or move the knob/slider that you wish to map.
- Type an appropriate action in the Action: box, e.g: mix_now
geposted Tue 15 Jun 10 @ 6:35 pm
VDJ script was not available in 5, right?
geposted Wed 16 Jun 10 @ 8:59 pm
You're right it arrived in version 6.0 - full history of what was introduced and when is available here: https://virtualdj.com/wiki/VirtualDJ_History.html
geposted Thu 17 Jun 10 @ 7:49 am
Sorry, I dIdn't notice the '5' - If the club upgrades to the latest v6.1 version https://virtualdj.com/buy/ then they can use the above mix_now mapping.
However, mix_now also exists as a shortcut in VirtualDJ v5 and can be mapped to a key via the keyboard mapper.
geposted Thu 17 Jun 10 @ 12:41 pm
