has noone noticed how bad the looping acuracy is with any loop of 1 beat or less? For example if your doing a slide loop (manualy not the plugin) and the loop will sound different every time it goes round like its not quite returning to the same place every time? triger a 1 bar or half bar loop exactly on beat and you will hear what i mean (not for dance music cause the beats are evenly placed and you wont notice it as much)
geposted Thu 02 Jun 05 @ 3:24 am
Disable the Time streching.
It's the TS algorithm that produce a random "drifting", and not the loop by itself.
I have reported this sometime.
geposted Thu 02 Jun 05 @ 3:21 pm
ok wel i feel sorry that your having problems with that too but this is with timestretch dissabled and with the pitch slider set to +0% so not related to to anything other than the looping feature.
geposted Thu 02 Jun 05 @ 7:40 pm
My appologies timestretch was indeed turned on! oops but this is stil a problem, timestretch is a good feature that i like to use. even so there is plenty of popping and unclear sound in the loop that stil could be sorted out
geposted Thu 02 Jun 05 @ 7:53 pm
Loops are perfect with TS off when the tempo is right calculated.
It means the song must have a constant tempo too.
TS needs improvement, this is a known issue.
geposted Fri 03 Jun 05 @ 12:04 am
Problem stills in 3.0...
FRUiT94
FRUiT94
geposted Tue 07 Jun 05 @ 4:44 pm
ok Mamnoon
geposted Tue 28 Jun 05 @ 1:32 am
