In the manual it says that the 1-6 sample buttons are programmable. How do you change them from default settings?
geposted Mon 28 Jun 10 @ 6:28 pm
On the DJ Console RMX skin, simply click on the down arrow to the right of each slot to choose what you want each of the 6 buttons to do.
NOTE: Assignment in the RMX DJ Console Edition is limited to a few common presets only. For full custom mapping capability, including ability to map any of the buttons to any function of your choice, you will need to upgrade to VirtualDJ Pro. Your RMX entitles you to a significant discount by going to https://virtualdj.com/buy/ and entering your RMX Consle Edition serial number in the box provided.
geposted Mon 28 Jun 10 @ 7:25 pm
