Forum: Old versions
Topic: Hercules DJ Console RMX wont show up in input
Hercules DJ Console RMX wont show up in input is there something i need to do other then hook it up to me computer? need help please
geposted Wed 30 Jun 10 @ 11:06 pm
If you are using v6.1 trial http://www.virtualdj.com/download/trial.html , then you will need to upgrade your DJ Console drivers and firmware to the latest version.
A link to download this can be found on the following page:
http://www.virtualdj.com/wiki/Common_Device_Drivers.html
NOTE: Your RMX DJ Console entitles you to a significant discount off upgrading to VirtualDJ Professional. To receive this, please go to http://www.virtualdj.com/buy/index.html and enter your DJ Console software serial number in the box provided.
geposted Thu 01 Jul 10 @ 5:24 am
I am trying to setup my Hercules console rmx with the virtual dj that comes with it. but I don't know where the serial number is located on the console
geposted Wed 12 Jan 11 @ 4:03 pm
It can be found on the sleeve of the installation CD.
If you have lost this, please contact the manufacturer Hercules for advice: http://ts.hercules.com
geposted Thu 13 Jan 11 @ 6:28 am
serial numbre PLEASE :'(
geposted Thu 08 Aug 13 @ 2:01 am
If you have lost the serial number for VirtualDJ LE, then you will need to contact the manufacturer to retrieve it. Please see http://www.virtualdj.com/forums/151663/General_Discussion/Lost_Serials_-_VirtualDJ_LE_or_any_other_version.html
Otherwise, you will need to purchase the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
For further assistance, please contact support: http://www.virtualdj.com/contact/index.html
If you like VirtualDJ, then please support the software and its future development by purchasing it.
Please also don't bump old topics that may no-longer be relevant to the current version of the software. This topic is from 2011 and is over 2 years old.
[Old topic closed]
geposted Thu 08 Aug 13 @ 3:46 am
