One advantage to using a computer for mixing is that it allows the DJ to act more as a producer and remix tracks on the fly
This sort of thing would be much easier to do with 3 or 4 decks to mix on
Would love to see this implemented in VDJ-7
geposted Fri 02 Jul 10 @ 6:16 pm
I agree, as I am improving, I have been playing allot with loops. There are many times where the mix soulds so good, I want to keep it going. Maybe there could be a command like "clone loop to third deck" to free up a deck for the next song? Just a though
geposted Sat 03 Jul 10 @ 8:20 am
+1
geposted Sat 03 Jul 10 @ 11:36 am
+1
geposted Tue 06 Jul 10 @ 6:00 am
Clone is good, but (4) Decks...Priceless....
Joey...
Joey...
geposted Tue 06 Jul 10 @ 10:02 am
Agreed, we were just saying a VDJScript command that could "close the loop on to a spare deck" would be a good feature. The verb Could receive a single parameter which would be the deck number...
Roy
Roy
geposted Tue 06 Jul 10 @ 11:43 am
yes, for 3 or 4 decks...i want mix more 2 songs.
please add 2 more decks thanks
geposted Sun 08 Aug 10 @ 12:57 pm
+1
geposted Tue 10 Aug 10 @ 11:44 pm
++++++++++1
geposted Thu 12 Aug 10 @ 3:37 am
+1 yeap!
geposted Sun 15 Aug 10 @ 6:34 am
+1 for a syncable third computer only deck alongside the sampler, so you can play more than just samples eg. Acapellas on time so you have greater remixing possibilities, Or maybe just make the sampler sync to the beat... It seems like a waste of an output with only two decks as you can run the sampler out of the main two channels anyway.
geposted Sun 15 Aug 10 @ 7:33 am
I was thinking of that the other day... How can most controler and time code users, could easily control a third deck. The only option I can easily come up with was the "clone loop to sample#". Then any user, can use the keyboard and nobody is left out!
Think about it for a second. You already have independant volume control. The only down side there, would be sync and BPM controls would need to be added to keep it timed properly. BPM is not really needed, but how can you keep a sample in time with the playing deck? That question, is for the experts!
Maybe the sampler needs a good amount of attention before that can happen. But This is actually reasonable. I have not needed it yet, but I have heard plenty of requests for speed control of samples around here (even on Serato's website, by their featured DJs). Add that and a wave form with syncing ability. Now you have 12 decks (well 14 if you count the main 2). This could be a real big idea!
geposted Sun 15 Aug 10 @ 9:51 am
Hey guys,
anyone out there mixing with a Numark NS7? have you figured a way to use all for with this controller?
geposted Thu 28 Oct 10 @ 5:04 pm
Please look at all the existing threads on the subject and ask your question in one of those.
This subforum is for feature requests, and this feature has been added to the software. Your question is one of support.
geposted Thu 28 Oct 10 @ 6:37 pm
