Forum: Old versions
Topic: Timecode Noismap setup
Hi
I have read the following https://virtualdj.com/wiki/TimeCode%20Config.html and it says the diagram for the input signal should have two circles joining bottom right corner, however mine are joining top left corner! why is is? Im using an audio 8 and serato timecodes that i downloaded.
It seems to work but does glitch everynow and then!
geposted Sat 03 Jul 10 @ 11:14 am
I have the same thing, and i use timecode flawlessly. I never really got why they added that it had to cross in the lower right corner. My signal works perfectly with a crossing in the top left.
audio 8 gives better signal then maya44?
Yes, although for timecode , Maya44 with RIAA phono filter enabled performs about equally good. Sound quality is just less with a Maya 44.
