Shaggypoet : It’s not a bug. My skin is in conformity with the default skin of the 3.0 version :
> Leftclick = Beatlock becomes smooth beatmatch (see the history of the 2.1 version)
> Rightclick does beatlock.
Serge.
Serge.
geposted Thu 09 Jun 05 @ 7:57 pm
Serge,
Got it. Thanks man.
Would be great if you could post what some of those buttons do on this skin. Master Tempo, Scratch button and others. It might be easy for professional Virtual DJ folks who have been using all the versions of Virtual DJ for a while, but for newbies sometimes a little explanation even if its obvious is helpful. Overall, I like the progression of this skin.
One suggestion, would be nice to see this skin in red. Let's say the gray parts are red and the Black parts white, the blue black, etc...Just a suggestion to give folks more options.
But definitely, a guide which each skin should be included so that folks know where everything is at rather then just experimenting for hours to find out what one button does.
Keep up the good work.
Gracias,
VDJ Batibiri
Got it. Thanks man.
Gracias,
VDJ Batibiri
geposted Thu 09 Jun 05 @ 10:32 pm
You have just given me a very good idea shaggypoet.
A guide for using each skin.
Anyway, be sure i'll put that in my next skin!
geposted Thu 09 Jun 05 @ 10:53 pm
The Pioneer CDJ-700 already has a guide he he!!
Anybody can work his manual in this forum I would stick the thread for sure. Here is mine (first page of the thread) : http://www.virtualdj.com/forum/display.html?topic=5053
geposted Fri 10 Jun 05 @ 9:46 am
