hello all I'm trying to record my mixes i have it set it record master input. while recording the computer detects both decks. what do i need to do so i will be able to cue in songs with out it appearing on my mixes.. i am also trying to ustream and its only detecting one deck,while its detecting that one deck im getting a loud wineing sound
thank u in advance
thank u in advance
geposted Thu 15 Jul 10 @ 7:16 pm
What is your sound card configuration?
geposted Fri 16 Jul 10 @ 12:37 pm
If you are using an external audio DJ mixer, then please see:
https://virtualdj.com/homepage/jpboggis/blogs/4135/Recording_your_set_or_broadcasting_when_using_an_external_DJ_mixer.html
geposted Fri 16 Jul 10 @ 12:46 pm
my sound card is the mayo 4-4 ..
i have a numark x6 and use time code cd, will i still be able to do this
geposted Fri 16 Jul 10 @ 7:43 pm
According to Numark's website that mixer has record outputs.
Because you are already using the line inputs of the Maya44 for timecode, you will need to use 3rd party software to broadcast and/or record. Connect a cable from the REC OUT of your mixer to the line input of your computer's sound card and then use this as your source in your broadcasting/recording software.
geposted Sat 17 Jul 10 @ 3:00 pm
