Forum: VirtualDJ Plugins
Topic: SBDJ Slideshow freezing
i was using SBDJ Slideshow for the first time in a live situation yesterday and it froze on pictures and wouldn't change to the next one. i activate and deactivate and it was still hanging on the same picture. i could open a new photo and it would continue to go through the pictures until it came to another picture it "didn't like" and would freeze again on the picture.
does file size or type have anything to do with it? there were jpegs and bitmaps in the folder when the freeze happened. after testing when i notice when it gets to a bitmap is when is stops. i moved all the bitmaps to one folder and i'm running the jpegs only and it seems to be working now.
so is it a file type or size issue a bug in the plug in or is it only designed got jpegs?
geposted Sat 17 Jul 10 @ 8:03 am
It's a file size issue. This has been eliminated in the newer version I'm writing.
ok great. thanks for the update.
