Can anyone try loading this sample.Hockey goal horn I can't get it to work.I've loaded other samples without any problems.
geposted Sun 18 Jul 10 @ 9:35 pm
Try to rename it from xx.vdj to xx.mp3 :-)
geposted Mon 19 Jul 10 @ 8:53 am
Thank you,that worked but it wasn't the horn sound I was looking for.I've searching for the one you usually hear on the radio between mixes.But at least now I know what to do if I come across the same problem.
geposted Mon 19 Jul 10 @ 2:48 pm
