Forum: Old versions
Topic: Syncing Numark MIxtrack with Virtual DJ
Hi just bought the new Numark Mixtrack controller and I'd like to be able to sync it with Virtual DJ. DOes anyone know how at all?
geposted Tue 20 Jul 10 @ 9:47 pm
Sorry, the Numark MixTrack is a new controller and is not currently natively supported (Plug 'n' play) in the current version of VirtualDJ. It may be supported in the next version and/or made available in the future as a downloadable add-on in the controllers section: https://virtualdj.com/addons/controllers.html
In the meantime, you may be able to map it yourself via Simple MIDI Wrapper or create your own mapper/definition for it - Please see https://virtualdj.com/wiki/VDJscript.html for further information.
NOTE: LED's and displays of the controller will not function with Simple MIDI Wrapper. A proper definition file and mapper is required for these to work.
any updates on when this will be supported?
It is included in the latest pro update 6.1.2 the demo for this is not yet available however.
Yes, the MixTrack is mapped and supported in the recent release.
