I have vdj pro on my pc then I bought a hercules mp3 controller which came with another vdj which doesnt have the same functions as my pro version i.e effects ect but cant get my pro versionn working with my controller, in the config i have it set to hercules, anyone any idea how to work it or why it wont work?
geposted Wed 21 Jul 10 @ 3:05 pm
Hi, then you use a old PRO version.
We are now at 6.1
Register your PRO version unter your profile and load the actual one.
After that, install the latest Hercules driver and it should work.
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=241&cid=1
We are now at 6.1
geposted Thu 22 Jul 10 @ 3:04 am
I've been running LE version with my VMS 4 since the DJ Expo. Today I decided to try the Pro version for 20 days. Clicked the button, followed the instructions to power down VDJ and restart. Did so, Pro came up for about 3 seconds then I got the blue screen of death. After trying to pinpoint to anything other than this update, I gave up and uninstalled VDJ. Did a reinstall, with all firmware and driver updates, and now when I click on try 20 day version, it tells me that I've already chosen this option and VDJ runs in LE mode only.
Any advice?
In addition, anyone having issues with the recording feature in LE? though everything sounds fine when mixing a set, the replay of the file bleeds mostly everything that is in cue.
BTW, only reason I haven't upgraded to Pro yet is that I'm awaiting for the upgrade portion of the sight to reflect the price promised to us VMS 4 customers at DJ Expo.
Thanks,
Jean-Pierre
Any advice?
Thanks,
Jean-Pierre
geposted Sun 05 Sep 10 @ 6:02 pm
And that was already done ... go here and enter your serial again --
https://virtualdj.com/products/oem.html
geposted Sun 05 Sep 10 @ 7:06 pm
