What webcamera works best with VDJ?
Would CREATIVE WEBCAM MOBILE work?
Thanks.
- Jim
Thanks.
- Jim
geposted Tue 19 Aug 03 @ 6:06 pm
most webcameras should work with VDJ but i dont know which is best
geposted Tue 19 Aug 03 @ 6:59 pm
Someone said me that all creative webcam he tried work with VDJ.
So yours should work :)
geposted Tue 19 Aug 03 @ 10:47 pm
I use a Logitech webcam messenger and it work fine (with last driver)
Coyote
Coyote
geposted Tue 19 Aug 03 @ 11:07 pm
I have used three different cameras with it and all worked fine.
1.ViewSonic (El-Cheapo!)
2.Veo (For the Laptop)
3. Old USR webcam (even has a dedicated PCI card for it!)
The one thing I have noticed is that the better the frame rate your webcam supports, the more receptive VDJ is to scratching.
Regards;
Redman247
Regards;
Redman247
geposted Wed 20 Aug 03 @ 9:14 am
Well. The creative webcamera mobile (notebook) can have two framerates: 15 (640x480) and 30 fps (352x288). Should I buy it?
geposted Wed 20 Aug 03 @ 9:19 am
30 FPS should be sufficiant for what you are doing, I am not quite sure on the resoloution though. Does the store you are going to buy this from have a good return policy? Perhaps the Atomix team could tell you what they tested VDJ with and at what FPS and Resoloution.
Regards;
Redman247
Regards;
Redman247
geposted Wed 20 Aug 03 @ 10:36 am
I'm not sure but VDJ must use a 160x120 resolution, so no problem for 30fps.
Could someone tell me if I'm right?
geposted Wed 20 Aug 03 @ 12:28 pm
how responsive is the scratching? do you need a special record ?
geposted Thu 21 Aug 03 @ 1:06 am
It will work best if the center of the record is 1/2 white and 1/2 black
geposted Thu 21 Aug 03 @ 1:33 am
WirelessDJ & AxldedentalDJ will test and review Virtual DJ web cam scratch feature *TONIGHT*
Equipment to be used:
2 technics 1200 MK2
dell inspiron 2650 laptop 1.6ghz pentium
upgraded 60gb HDD with removable sleds
logitech usb web cam (borrowed)
6000+ mp3 tracks
Registered virtual DJ 1.05 software with all skins and plug ins installed
Visiosonic DAC-2 controller
2 technics 1200 MK2
6000+ mp3 tracks
geposted Fri 22 Aug 03 @ 2:03 pm
geposted Sun 24 Aug 03 @ 2:43 am
