Hi all,
I was wondering if there were any other effects downloadable that I could use on virtual DJ besides the ones in the download section. I am using a mac so this kinda limits my choices to a few effects only
geposted Thu 29 Jul 10 @ 9:50 pm
Only those found in the download area with the Mac floppy disk download icon are currently available for Mac.
Most effects and other plugins in the download area are created by talented users of VirtualDJ. If the author does not own a Mac and/or has not created a Mac compatible version of their plugin, then unfortunately it will not be available for Mac.
geposted Fri 30 Jul 10 @ 3:56 am
I just bought VDj and I am a Mac user. Have to say that I am very dissapointed in the amount of add on's available for my Mac. I can't even overlay images. feel very ripped off.
geposted Mon 18 Oct 10 @ 11:03 pm
Did you check before you bought that the effects you wanted were available on Mac?
As has been stated over and over and over: Plugins are usually user created. Not all users - like me for example - have a Mac.
geposted Tue 19 Oct 10 @ 4:13 am
this my question: what I'm going to do to hear the disk 2 by using a headphone to choose the next remix song while the disk 1 is playing. i'm using a PC speaker and headphone..hope u will help me..thanx a lot
geposted Fri 22 Oct 10 @ 11:02 am
Please ask your question in the correct forum - http://www.virtualdj.com/forums/20/PC_Version_Technical_Support.html - It has nothing to do with using sound effect plugins (Add-ons.)
Also, please do not post the same message or question in more than one topic.
geposted Fri 22 Oct 10 @ 11:33 am
I have made some effects in Garageband and loaded them in VDJ. Works fine.
geposted Sat 23 Oct 10 @ 8:42 am
