VDJ should have a 'beat count meter' which would indicate beats remaining to end of song.
There should also be the option to automix by beats remaining instead of by 'seconds'.
geposted Tue 07 Jun 05 @ 5:06 pm
1) You can do that by changing the xml file of the skin
2) My plugin XFade works in beats ;-)
geposted Tue 07 Jun 05 @ 5:16 pm
Thats great, but I dont know how to program in xml.
If you were to provide instructions, is it simple to change to code?
geposted Tue 07 Jun 05 @ 5:20 pm
use in the textzone:
B : display the value as a number of beat instead of a time
http://www.virtualdj.com/support/developers/skin.html
geposted Tue 07 Jun 05 @ 5:32 pm
Thank you very much, I think I can do it based on what I see.
I will try it out and post my progress, thanks again.
geposted Tue 07 Jun 05 @ 5:36 pm
You're welcome
geposted Tue 07 Jun 05 @ 5:37 pm
Some skins already display the info you want.
Try the pioneer 700 (the colour version or the original.)
geposted Tue 07 Jun 05 @ 6:21 pm
@djcel where can be found that xfade plugin, please ?
geposted Tue 07 Jun 05 @ 6:37 pm
In the download plugins section:
http://www.virtualdj.com/addons/view.html?type=effect%20plug-in
geposted Tue 07 Jun 05 @ 6:48 pm
sorry i walked thru the whole section and did not find it (overlooked)
for the second try i found it ;-)
sorry, got to get some glasses
geposted Tue 07 Jun 05 @ 6:55 pm
