Tonight towards the wnd of the night. I played a 11 mix that stopped loading after 15 seconds. It Play ok, but kept loading song as it played. After that every song I put on that deck (no mater what size) also only loaded a little and barley kept ahead of it's self till the end as it played. The other deck played fine for about 10 more songs then that started doing that too. This has happened to me 3 times this month. Also a few certain songs don't load all the way like disturbia no matter what copy and yes they are from different cds even.
any help would be great Tim
Using cue 6
Using cue 6
geposted Sun 01 Aug 10 @ 5:10 am
are you using a full legal copy of cue?
geposted Sun 01 Aug 10 @ 10:05 am
Yes I paid $299 on ebay from a authorised dealer Comp-U-Store. I am regestered on Cues site, wich dosn't have a forums
geposted Sun 01 Aug 10 @ 11:58 pm
Please register your Cue serial on the page https://virtualdj.com/buy/ and then update to the latest version https://virtualdj.com/download/updates.html
If you load a song that's longer than your Max Load setting (CONFIG -> Options) then it will be streamed directly from disk (Waveform will load as the song plays instead of loading all in one go.)
geposted Mon 02 Aug 10 @ 5:36 am
