Can you scratch with dac-2....anybody know of any videos on dac-2?
geposted Tue 07 Jun 05 @ 8:30 pm
perhaps,
and if so, who will scratch on a jog of 1,5"
it is hard to scratch on a real vinil , who can be acurate on a little jog weel.
but to anser to the question, i think it is possible if you create the appropriate DLL, if you use the normal config, it is not possible
geposted Wed 08 Jun 05 @ 2:32 am
Yes it is possible. I have been able to dos this, but you need to modify the DAC-2 to and remove the springs from the jog wheels. It is very involved process and I would not recommend doing it unless you are an electronics technician
I had a video posted a while back but ran out of space and had to remove it!
WirelessDJ
WirelessDJ
geposted Wed 08 Jun 05 @ 2:42 am
Thanks for the response...... I guess I will wait to see what Bahrenger has.
geposted Wed 08 Jun 05 @ 5:28 am
ALthough you can alter the DAC-2 I would not reccomend it. Go with TCV.
geposted Wed 08 Jun 05 @ 5:40 am
