Can anyone explain to me the proper way to configure the Echo Indogo DJX card for a macbook pro?
I would appreciate it.
Thanks!
Scott
Thanks!
Scott
geposted Tue 03 Aug 10 @ 8:46 am
Just a courtesy bump.
geposted Thu 05 Aug 10 @ 9:01 am
Try to set the 2 cards out mode on VDJ and set the Echo Audio panel to use Virtual out 1-2 on real exit 1-2 and the same for 3-4, virtual out 5-6 and 7-8 can be Muted.
If you don't be able to find correct setup contact service support https://virtualdj.com/contact/
geposted Fri 06 Aug 10 @ 4:19 am
