Just some questions on the Fame Settings.
What are some suggestions to setting the Force Fade, fade length, limiter,time stretch and disengage beatlock, what are the differences in the settings?
geposted Wed 08 Jun 05 @ 5:34 am
All your questions have answers in the manual.
https://virtualdj.com/support/VirtualDJ%202%20-%20User%20guide.pdf
{select and copy and paste the whole URL}
However, some suggestions are:
Limiter and/or Time Stretch - Enabled for some produce a poor quality in sound, however; I use both enabled. It's really a try and discover for your own needs.
Disengage BeatLock - I set to 'on Load' , I never use BeatLock personally, but just incase it gets activated I have it set to Disengage when a new track is loaded to the deck.
The following all config the 'AutoMix' performance:
Force Fade - I set to 'Disabled'
Fade Length - if I am AutoMixing Video I have the fade set to about .3 - .5 sec, if I am mixing audio then I set is to about .9 - 1.1 sec. -- this is the amount of time VDJ using to complete the Fade between decks.
CrossFader - I tend to use Smooth or Full, it varies on the use - Video vs. Audio
Hope this helps.
cstoll
Hope this helps.
cstoll
geposted Wed 08 Jun 05 @ 5:53 am
It certainly does, thank you so much!
Cheers,
Niki
Cheers,
Niki
geposted Thu 09 Jun 05 @ 12:24 am
@ Nikik,
Don't forget the search tool, many questions have been submitted in the past, even maybe some of yours...
You're welcome!
FRUiT94
You're welcome!
FRUiT94
geposted Thu 09 Jun 05 @ 12:32 am
