Hi, I purchased my Hercules RMX a little while ago and got quite comfortable with it. I was using the LE version of VDJ that came in the package. The layout was exactly what I wanted. Buttons 1 & 4 for loop in & out, buttons 2 & 5 for bend - & bend +, button 3 for flange and button 6 for brake. Everything worked fine until I upgraded to 6 pro. All of the buttons are different and I have no clue how to program them.
I have tried learning VDJscript but it just seems overly complicated for something as simple as programming a button. I just want to be able to program them back to what they were.
Any assistance would be appreciated.
geposted Thu 05 Aug 10 @ 5:56 pm
The effect buttons were re scripted as DJC buttons in VDJ 6. Your old skin stes the "Effects", but now your RMX buttons work as DJC buttons.
My skin was https://virtualdj.com/addons/7329/RMX_Mod_Don_Houde.html updated for 6. Nothing special and there are may others out there that work fine too. But this skin is set up for DJC buttons, so you can just click on your effects like you could before in LE.
Also, before you abandon your skin, I think that if you hold 1 of the "Effect" buttons on the RMX that you want to program for a second or 2, when you release it, the DJC menu will pop up. Allowing you to select what you want that button to be as well.
Good luck
Good luck
geposted Thu 05 Aug 10 @ 10:20 pm
