Does any1 know how to add a shortcut which changes the size of your loop?
On the default skin interface there is a button which does that using the < > arrows. It goes incrementally with the default size of the loop 4 beats. When you click < it goes down to 2 then 1 then 1/2 the 1/4 and so on. > is opposite going from 4 to 8 then 16 etc.
Can you map this function to the keyboard? Also the other command of shifting the loop cue point is another useful function, except I have no idea where to locate the commands let alone type in the parameters.
I use xp10's so if someone could help me map it to buttons on there it would be great. If not keyboard would still be good.
Help please!
Help please!
geposted Thu 09 Jun 05 @ 5:55 am
