Forum: Old versions
Topic: New To Virtual Dj :)
Hi everyone im just waiting on my RMX - DIGITAL DJ CONSOLE to be delivered tomorrow what i wont to know is can i install my software pro before my deliver or do i have to wait?????
Thanks
geposted Wed 11 Aug 10 @ 6:56 am
The Rmx is obviously supported by the pro version, so you can go ahead and install it right away if you want. Also think of entering your serial number in the forum profile , which will give you access to the latest update (currently v6.1.1).
Once you receive the Rmx, simply install the latest drivers (2010.HDJS.2), available from the support site , and you'll be ready to go:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
Note that in order to use the Rmx in VDJ Pro, you will need to configure it under SOUND SETUP. You should apply the following configuration to get started:
- Input : None
- Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
-Soundcard: DJ Console Rmx
You can install the Pro version anytime,
Your showing up as a NLU? have you purchased the Pro software already? (the RMX only comes with VDJ LE, not pro)
Why write my serial number in my profile?
According to the serial number you have, you will get a specific level. This will give you access to new advantages like limited or faster support, limited or full plugins, skins, tools etc....
Another reason to register your serial number is that if you loose it, it will be very easy for us to find it in our database.
At last, professional edition users will be able to download updates.
https://virtualdj.com/wiki/FAQ.html
