I think we need more than 3 band equalizer for example a 32 band equalizer.
there are plugins for 32 band equalizer but they are on the plugins creen which is not easy to get to while Dj'ing.
It will be great if we could put the UI of the plugins on the main skin window and then we can use a Equalizer Plugin.
by the way , Is the Plugin Equalizer working on both decks or i should load it on both decks?
10x
10x
geposted Thu 09 Jun 05 @ 12:15 pm
