Hello,
While the development of new features for VirtualDJ is going well, and we should be able to release a new major version very soon, in the meantime we will continue to release occasional maintenance-releases.
So here is VirtualDJ v6.1.2.
The changelog from 6.1.1 is not big, but we found a small bug in 6.1.1 that could eventually lead to a crash when using a Pioneer CDJ2000.
Even if this crash was very unfrequent, we try to keep a zero-crash policy, so we had to release a fix asap.
This fix also fixes a few old controllers that got some of their LEDs broken by the latest update (6.1.1), namely the DAC3 and some Denon controllers.
The complete (if short) changelog is on the history.
As usual, the upgrade is free for all BASIC/PRO users, as well as Numark CUE/VV users, and recent LE users.
Go to your download center to download it.
geposted Thu 12 Aug 10 @ 2:58 pm
Hi. Thanks for the update.
geposted Thu 12 Aug 10 @ 3:22 pm
Once again, Thanks for the update!
geposted Thu 12 Aug 10 @ 3:38 pm
THX FOR THE UPDATE....NE UPDATES COMIN FOR THE MIXDECK
geposted Thu 12 Aug 10 @ 4:29 pm
Thankz I Will Try It Out On Saturday @ The Car Show 9-6pm And Monday Night 8-1am.
geposted Thu 12 Aug 10 @ 5:26 pm
This update includes an improved mapping for the mixdeck which can drive the screen text and jog LEDs.
This update is also available for Cue and VV.
geposted Thu 12 Aug 10 @ 5:44 pm
Yay!
geposted Thu 12 Aug 10 @ 5:47 pm
THANKS ALOT VDJ FOR THE UPDATE ONCE AGAIN
geposted Thu 12 Aug 10 @ 7:32 pm
Thanks again for the good work. Any news on a mapper for BCD2000? Need Mic and headphones mapped.
Cheers
Cheers
geposted Thu 12 Aug 10 @ 7:35 pm
I was hoping the DN-X1600 would be included in the next release...
Welll, soon enough~
Thanks guys!
Welll, soon enough~
Thanks guys!
geposted Thu 12 Aug 10 @ 7:54 pm
great job .... amazing service as always ...............thanks
geposted Thu 12 Aug 10 @ 8:40 pm
guys many thanks
and that from a new user
keep up
keep up
geposted Thu 12 Aug 10 @ 9:21 pm
Is there any new controllers supported? Like Vestax Typhoon?
geposted Thu 12 Aug 10 @ 11:34 pm
i did the update but the leds aruond jog wheel for mixdeck did not light up and no text display on mixdeck what do i need to do for it to work. Thanks in advance
geposted Fri 13 Aug 10 @ 12:58 am
Go in config/mappers and click on "revert to factory default" (the icon with a CD and a box).
You probably have some left-over from previously installed custom-made mappers.
geposted Fri 13 Aug 10 @ 5:12 am
Do you know if the upcoming release will finally fix the mic issue on the American Audio DP2?
geposted Fri 13 Aug 10 @ 8:19 am
thanks vdj staff for your response. i did exactly what you recomended but the leds around the mixdeck jog wheels do not light and the text song tiitle artist is not displayed on the mixdeck . time and bpm is displayed as it was w/ the previous mapper. Any suggestion would be greatly appreciated
geposted Fri 13 Aug 10 @ 8:42 am
Kevin ...
If you previously downloaded the definition/mapper files from this site ... please go to the Documents\VirtualDJ\Devices folder and delete the MixDeck definition. Also, even though you did the 'refresh to defaults' go to the Mappers folder as well and delete the MixDeck mapping file (if it exists).
Chris
Chris
geposted Fri 13 Aug 10 @ 9:24 am
CSTOLL THANKS FOR THAT the leds on the mixdeck is now lit up. How can i get the text to display on the mixdeck? thanks in advance. Cstol i think the mixdeck is great how do u like the mixdeck
geposted Fri 13 Aug 10 @ 9:44 am
Is the song title information displayed when you use Traktor if not you may require a firmware update.
You can obtain this by contacting Numark support.
