If you have a loop going and you push the automix function, the mix will go no farther than the loop.
Meaning, I hit loop on deck a (8 beats) and then hit automix. THe mix starts to happen, but then re sets to deck a every 8 beats.
Sometimes you do want a loop and automix at the same time.
Comments?
Ronny582
Comments?
Ronny582
geposted Thu 09 Jun 05 @ 6:59 pm
I never use automix, but i will try.
Dj Nikki
Dj Nikki
geposted Thu 09 Jun 05 @ 8:29 pm
Yes you're right. In fact i think automix is the opposite of my plugin XFade. i mean they should have taken the other deck to move the crossfader contrary to my plugin which uses the deck linked to plugin (by working with samples)
So in (auto)mix you can't enter in a loop and in my plugin you can't exist from a loop.
geposted Thu 09 Jun 05 @ 10:13 pm
Exactly my good sir!
geposted Sun 12 Jun 05 @ 8:54 pm
